In one of our Siemens drive power module PM240, IGBT module FS225R12KE3-S1 is in use, but on Infineon webside we can find information about FS225R12KE3 only. What does S1 mean in our part no. Is it same as FS225R12KE3 ?
As I told you earlier , both the part numbers are same. Only difference is S1 is tested with Siemens specific grouping.
I hope this explanation clarifies your doubt. Let me know if I could help you more on this.
BR,
AZIZ HASSAN
Thank you for posting at Infineon community.
Yes, both the part numbers are same. S1 means electrical selection and I could give you more information regarding it in few days.
PFA for your reference.
BR,
AZIZ HASSAN
BR,
AZIZ HASSAN
Thank you Mr. Hassan. 👍
