IGBT Forum Discussions
User17756
First question asked First reply posted
Hi all,
can someone explain the difference between the EconoPack+ B and D series?
For example, 450A 1200V device is available in both versions.
Thanks!
AlexG
Moderator 10 solutions authored 10 replies posted 5 solutions authored
Hi JoFoe,
First of all pin and power terminal positions of EconoPACK™+ D-series as well as module dimensions are identical to EconoPACK™+ B-series.
D-series modules has following improvements:
- lower internal inductivity;
- ultrasonic welded power terminals;
- pressFIT control terminals;
- injection molded power and control terminals;
- improved TC curve.
Infineon recommends to use EconoPACK™+ D-series for the new designs.
You can find more information here.
BR
AlexG
Hi JoFoe,
BR
