IGBT Forum Discussions
User17668
5 replies posted 10 questions asked 5 questions asked
Hi Infineon,
I heard several times from the new Easy3B - can you please explain what it is about and where are the differences to the already existing housings?
Thanks and BR
AlexG
Moderator 10 solutions authored 10 replies posted 5 solutions authored
Hi Melli,
This is a new package in our Easy Power Modules family. The Easy3B has the size of two Easy2B integrated in one single package and has the same height as other Easy packages (12mm).
The package has a new housing material, which is suitable for higher DC link voltages.
PressFit pins provide a connection of the module with the PCB under low contact resistance and enable an efficient production, by reducing the assembly time.
With the new package we can increase the power rating up to 45kW with our IGBT7 chip technology.
Please follow the news on our webpage.
BR
AlexG
Hi Melli,
BR
