Hi @lchalmers,
thank for the information.
Unfortunately, we don't have such kind of configuration modules.
but you can still use Infineon silicon IGBT with separate SiC anti-parallel diode.
Malleswararao
Hi @lchalmers,
thanks for posting your query in the Infineon community forum.
To facility your requirement, we may need more information like
Application :
operating switching frequency :
DC bus Voltage :
output current :
cooling method :
so that we can suggest the most suitable part for you.
Malleswararao
They are needed in a pieces of testing equipment we are building. I have been looking at the FF400R17KE4, I need 400A, 1700V with a SIC diode inside, no sure if this part has that. Sorry that is all the information I have at the moment.
Hi @lchalmers,
Malleswararao
