NXTY_Yoshimura
Level 4
Level 4
Distributor - NEXTY (Japan)
10 solutions authored 10 replies posted 50 sign-ins
Dear all,
Regarding FP50R12N2T4 and FP75R12N2T4,
do you have Converter Power Loss Curve , which is the “ AVERAGE FORWARD POWER DISSIPATION “ of attached file ?
BR
Abhilash_P
50 likes received 500 replies posted 250 solutions authored
    Calculating the power loss curve is not possible because it is highly dependent on current waveform seen during operation.
Therefore, as a first step, we would have to do the calculation manually and with a theoretical approach.
For power loss calculation on the rectifier side (per diode), please use the following formula.
*Iav(per diode)=0.33*Idc
*Idc --> From customer operation
*F --> depending on the current waveform. For B6 configuration (our case), and if we assume ideal induction loads we can consider a Form Factor of 1.73.
Abhilash P
Abhilash_P
Abhilash P
