Hi all,
We are considering the use of the following products.
・FF600R12ME4_B73
・FF600R12ME4P_B72
・FF600R12ME4W_B73
・FF600R12ME4_B72
I have a question.
Could you please tell me how FF600R12ME4 (standard product) is different from _B72 or_ B73?
MS
- _B72
B72 and B73 modules have thicker DCB ceramic than standard modules, therefore, the B72\73 module is 4kV-AC-isolation, standard module is 3.4kV-AC-isolation, but the Rthjc is slightly higher due to the thicker DCB ceramic.
B72 is standard auxiliary pin which are soldering connection with PCB, B73 is PressFIT pin.
Please correct me if I am wrong. You are asking about difference between FF600R12ME4 and FF600R12ME4_B72/B73 ?
BR,
AZIZ
Your understanding is correct.
MS
Thank you for your prompt reply.
MS
