- Email to a Friend
Hi, Please tell me about F3L400R07W3S5_B59.
If you check the internal circuit diagram, the IGBTs on the High side and Low side of the 3-level circuit are configured in parallel. What is the reason for this?
Modul number:F3L400R07W3S5_B59
- Email to a Friend
In light load conditions if two switches are operated in parallel the switching loss will be slightly
more compared to the single switch loss. But ultimately the losses will depend on the ON & OFF
strategy (PWM technique).
The main reason to provide a configuration like this is chips are fast and they do not have internal
gate resistors. We need separate Gate Emitter pins for better controllability and paralleling.
Please feel free to contact me if any other details are required.
Akhil Kumar.
- Email to a Friend
Thanks for posting on the Infineon community page.
To meet the required nominal current of 200A and especially with fast switching nature, it is
required to have two S5 chips in parallel.
In light load conditions, this module can be operated with a single switch to reduce the losses.
Please let us know if any other details are required.
Thanks & Regards,
Akhil Kumar.
- Email to a Friend
Akhil Kumar-san
Is it okay to understand that the reason why the high side and low side gate terminals that are in parallel are not one but are configured separately is that they can be driven by one element under light load?
Also, I'm sorry for the lack of study, but could you please tell me the reason why the loss is reduced by one element in the case of light load?
- Email to a Friend
Akhil Kumar.
