s27kl0642 IBIS Model
user_4698121
Currently I am working on signal integrity analysis of s27kl0642 model but I did not find ibis model.
https://www.cypress.com/ibis/s27kl0641-ibis?source=search&cat=software_tools
I can find only s27kl0641 but this model and my model is different.
Can you share ibis model of s27kl0642 with me?
Thanks for help.
PradiptaB_11
Please find the model below.
Pradipta.
PradiptaB_11
Pradipta.
Hi PradiptaB_11​,
Thanks for file, end of the file name write 3V this only can be use 3V or can I use for 1.8V?
Can you use this file all my analysis?
Thanks for help.
The attached file is for part S27KL0642 which is a 3 V device. If you want a IBIS model for S27KS0642 which is 1.8 V device then you have to use the below IBIS model as attached.
Pradipta.
HiPradiptaB_11​,
My hyperram package is S27KL0642GABHB020.
Your file related with S27KL0642DP.
Can you share with me S27KL0642GABHB020 ibis files?
Thanks for help.
Hi Mustafa,
The IBIS file states that it is for 24 ball BGA package. The Hyper ram memory comes in 24 ball BGA package only. So you can use the IBIS model. It is applicable for S27KL0642GABHB020.
Thanks and Regards,
Pradipta.
Thanks for help.
