Hyper RAM Forum Discussions
clab_4481021
I try to integrate the verilog model for S27ks0641 with the synopsys SSI IP.
I got the following:
Warning!  Timing violation
           $skew( negedge CSNeg:414195 PS, posedge CSNeg:498597 PS,  1 : 1 PS );
            File: s27ks0641.v, line = 369
           Scope: ssi_tbe.mem_model
            Time: 498597 PS
I modified the value in the verilog file of tskew_CSNeg_CSNeg from 1 (tCSM) to 100000 to avoid it.
we run in 166MHz and the time between fall(CSNeg) and rise(CSNeg) can not be 1 ps
not sure why this value was set to such a short time?
the skew command requires a time interval of 1 ps max for CS to be active - that is not enough to deliver a Hyperbus frame.
can you please clarify?
Best wishes,
Cluny
Could you please let me know, whether you are using the latest Verilog model for S27KS0641 available at: https://www.cypress.com/documentation/models/verilog/s27kl0641-s27ks0641-verilog ? If not, please use this model for your simulations and let us know the results.
Thanks and Regards,
Sudheesh
SudheeshK
250 sign-ins First question asked 750 replies posted
Please find our comment about your query below.
"The tcsm (CS# Low maximum) time is checked with this. It is covered in the spec and recommended value is 4 us. In the Verilog sdf:
(SKEW (negedge CSNeg) (posedge CSNeg) (4000))
What is the timescale you have used? SDF timescale is set to 1 ns.
About tdevice time, as usual we do not recommend changing this because we haven't tested it, but in this case I guess it is ok. There is no other way of doing it.
Other option is to use VHDL model where tdevice_VCS parameter can be changed through instantiation."
Thanks and Regards,
Sudheesh
Hi Sudheesh and thank you for your reply.
regarding the tcsm:
i am using timescale of 1ps
as we might send long write/read trans the time of the assertion of CS (low) can be 3000ns end even more - so i do not undesrtand why the tcsm was set to 1ps originally (even 1 ns is too short).
as i said - i have changed it and it solved - but i want to make sure i didn't violate something and that we wont be failing when we use the real HyperRam with its defined timing.
So how a value of tcsm=1 can be enough to deliver long streams?
best wishes,
Cluny
Thanks and Regards,
Sudheesh
