- Email to a Friend
Hello
I'd like to check and use for my test board using hyperRAM solution.
Can I get full datasheet of S71KS512SC and S27KS1281DPBHA02?
Thank you
Memory Hyper Flash
- Email to a Friend
Hi
Kindly use the below link for access to all the datasheets for HyperRam products. The part numbers you have mentioned does not seem to be valid. You can check the documentation tab from this link which will list out all the datasheets for you.
https://www.cypress.com/products/hyperram-octal-xspi-ram-memory
Pradipta
- Email to a Friend
Hi
Pradipta
