I have a question about < write buffer program> of s26ks hyperflash.
I want to write multiple word using sequence like this "555->AA->2AA->55->SA->25->SA->WC->WBL->DATA->DATA->DATA", which use single "WBL" followed by multiple words data. Maybe this is different with datasheet as picture below.
My experiment results are those:
1) In RTL simulaton using s26ks hyperflash Verilog model, my write buffer program command( "555->AA->2AA->55->SA->25->SA->WC->WBL->DATA->DATA->DATA") succeed.
2)When i run same code in real s26ks flash memory, it failed.
So, i want to ask if s26ks can support write buffer program like "555->AA->2AA->55->SA->25->SA->WC->WBL->DATA->DATA->DATA" or not?
Thanks a lot.
Memory Hyper Flash
This question is being discussed here.
