When I use s26kl512s flash model for RTL simulation, I send command to read device id, and flash responsed id information correctely. command sequence as below:
Then I send word program command to write data to flash, but i found program operation do not really work.
Word program command sequence as below:
first transaction
second transaction
third transaction
fourth transaction
In my case, if i don't send read device id command, my word program can work well.
I wish i can get some advice from cypress,
Thanks a lot.
yongkang
Memory Hyper Flash
Thanks very much for your attention. But now I have soved this problem, I sended <ASO exit> command after <ID-CFG read> command, then word program works well.
However I have another problem, it is very, very, very urgent, I hope you can pay more attention to it.
The question link is s26ks512s flash: bit5 of MSB in a word always has... - Cypress Developer Community
Thanks very much.
Thank you for contacting Cypress Technical Support, an Infineon Technologies Company. Currently we are viewing your issue and will get back to you as soon as we find the resolution.
Thank you
Bushra
Thanks very much.
