I can not erase the s26Ks512 , after the erase operation, i got the status register code 0xA2. that mean the chip is locked,but the ppb and dyb code both were 0xffff.
Hi Jack Su,
I discussed this issue internally with our product experts. Please find our comments below.
As per the datasheet the pin A3 is DNU (Do Not Use), it is connected internally and we recommend to leave DNU pins unconnected. But, in your schematic, the pin A3 is pulled up and connected to M_FLASH_CS2 signal. What is the voltage on the pin A3 during an erase operation? Can you make this pin floating and test again?
Thanks and Regards,
Sudheesh
Hi Jack Su,
Are you facing this issue (erase failure) with all of the sectors? Or, only few sectors are showing this error? Please clarify.
Is it possible for you to provide logic analyzer traces for sector erase, ppb read and dyb read operations?
Thanks and Regards,
Sudheesh
Hi Sudheeshk,
thanks for reply,
the s26ks512 is map to the memory address 0x90000000 to 0x94000000; and i try to erase all the chip ,but failed with read the status register code bit 1 set to 1, which show the reasons for failure is sector's locked, this also happend when program the 0x90000000 and 0x93840000. the s26ks512 is new from factory. driver code come from offical version Spansion_pNOR_LLD_15.3.1.exe.zip ,
here were the code
lld_PpbEntryCmd(testBase);
u32Count =lld_PpbStatusReadCmd(testBase, 0);
lld_PpbAllEraseCmd(testBase);//erase ppb
lld_PpbExitCmd(testBase);
//DYB read out as 0xffff
lld_DybEntryCmd(testBase);
lld_DybClrCmd(testBase, 0);
u32Count = lld_DybReadCmd(testBase, 0);
lld_DybExitCmd(testBase);
//NVCR read
u32Count = lld_ReadNonVolatileConfigRegCmd(testBase);
//VCR read
u32Count = lld_ReadVolatileConfigRegCmd(testBase);
lld_ChipEraseCmd(testBase);
// FLASHDATA wrdata=0x000;
// lld_ProgramCmd(testBase,0,&wrdata);
lld_StatusRegReadCmd(testBase);
//status register read out as 0x00A2
u32Count = M16(testBase);
here were the logic analyzer traces of read and write.
Hi Hi Jack Su,
Thank you for the details. You have to poll status register after every program and erase operations before starting new operation. You have poll status register after ppb erase command and chip erase command. Please make the below modifications to you code and test again.
1. Replace the API "lld_PpbAllEraseCmd" with "lld_PpbAllEraseOp".
2. Replace the API "lld_ChipEraseCmd" with "lld_ChipEraseOp".
Thanks and Regards,
Sudheesh
Dear Sudheeshk,
I try replace the API as your reply, but still got the error code 0xA2 . i try to locked the PPB then unlocked, the locked is failed,even the PPBlockbit readback as 0xffff, the DYB and PPBLockbit can be program,erased and read back correctly, can you give some suggestion, thanks a lot!
Hi Jack Su,
As per my understanding, you are not able to erase any of the sectors in our device S26KS512. Both, sector erase and chip erase operations results in error (status register = 0xA2) even though the PPB bits are not programmed. Please correct me, if I am wrong.
To get a better understanding about this issue, could you please provide the below detail?
- Are you able to read device ID from our device S26KS512?
- Are you able to program any of the sectors in the device S26KS512?
- Can you read status register value before the erase/program operation and make sure that none of the error bits are set?
- Can you share the schematic diagram of your application? We can review it and let you know ,if there are any changes needed.
- Can you share your source code with us? We can check if any modifications needed? If not, please share the "FlashWrite()" and "FlashRead()" function definitions.
Thanks and Regards,
Sudheesh
Hi Sudheeshk,
thanks for your warm-hearted reply,
1. I can read the content of deviceID and the SSR. and they were same as the DataSheet.
2. I failed to program two Sectors, first sector at 0x90000000,and the secotr at 0x92000000. both can be checked by lld_BlankCheckCmd as blank sector and PPB and DYB of them were 0xFFFF.
3. the status register code were 0x80, before program and erase, and after the operation, turn to 0xA2,or 0x92.
4. give me your email,and i'll send you complete schematic diagram.
Hi SudheehK,
Regarding the issue,the latest progress on my side as below,
I read out all the sector's SA protection status register, all of them were 0xfff6.
the datasheet describe this register ,as below
Data out during a SA Protection Status Read indicates whether the indicated sector is protected in bits 0-2.
Bit 0 – Indicates whether the indicated sector is protected (0 = protected, 1 = unprotected).
Bit 1 – Protected using the sector’s DYB bit (0 = protected, 1 = unprotected).
Bit 2 – Protected using the sector’s PPB bit (0 = protected, 1 = unprotected).
looks like the sector is really be locked, i don't know how it was locked, do you have some suggestions, thanks
Hi Jack Su,
I have sent a separate email from my official email ID yesterday.
Could you please reply to my email with your source code?
Thanks and Regards,
Sudheesh
Hi Jack Su,
Thanks and Regards,
Sudheesh
Hi SudheeshK,
The situation is indeed as you said, the problem has been solved, thank
you very much for your timely and effective support!
On Wed, Dec 18, 2019, 6:02 PM SudheeshK_26 <community-manager@cypress.com>
Hi Sudheeshk,
here were another status. i can't set the PpbLockBit to zero. the code as below:
u32Count = lld_PpbLockBitReadOp(pBase); //read out as 0xffff. the orginal value
FLASHDATA* pBase = (FLASHDATA*)0x90000000;
u32Count =lld_PpbLockBitSetOp(pBase); //i thought this operation will make the PPB lock bit to 0;
delay(2);
u32Count = lld_PpbLockBitReadOp(pBase); //read out as 0xfffe only the last bit is set to zero.
