Josh2423
The blank check on S29GL128S10FHIV20 does not work for me.
I issue the command:
(*flash_cfi_dev->write_native)((alt_u8*)flash_cfi_dev->dev.base_addr + addr + 0x555, 0x33);
and then repeatedly the command:
status = IORD_8DIRECT(flash_cfi_dev->dev.base_addr + addr, 0); // Read status register
waiting for bit 0x80 to drop, indicating that the erase check has started.
Then I wait for the erase check to finish.
If I use the command
I always get 0x28. No matter how long I wait.
When I use the command sequence:
(*flash_cfi_dev->write_command)(flash_cfi_dev->dev.base_addr, 0x555, (alt_u8)0x70);
I always get 0x80.
I get the same above results whether the sector is erased or not.
BushraH_91
250 solutions authored First comment on blog 500 replies posted
Thank you for contacting Cypress Technical Support, an Infineon Technologies Company. Currently we are looking into the issue and will get back to you as soon as we find the resolution.
Bushra
BushraH_91
Please confirm that the all other commands like program/erase/CFI read are working on your system.
Thank you
Bushra
Hi Bushra, Thank you for the follow-up.
Yes, all other commands (read, write and erase) work great.
Josh
BushraH_91
So, please share your code snippet for sector erase.
And the part number is VIO model. Please make sure you supply VIO correctly.
Thank you
Bushra
