Could you please help to provide the full spec of S28HS512Tx.Thanks!
Memory Hyper Flash
Hi @ericlu
Are you a member of the SEMPER Early Access Program?
If yes, you will be able to access the full datasheet on this link.
If you are not a member yet, I would request you to register yourself here - registration link. Once you complete your registration, You will receive an email with further instructions. Please respond to it and then you will be provided access to the datasheet.
Regards.
Hi @ericlu
Regards.
