Hi all,
are there example driver Libraries available for S26KS512S in context of Linux? We are using the Hyperflash together with an SoC solution from TI (Jacinto).
Thank you in advance
Michael
Hi Michel,
if you have memory mapped access to the Hyperflash in your system, you can run the standard Linux pNOR MTD driver (drivers/mtd/chips/cfi_cmdset_0002.c) on that address range. Only small changes are needed for KS-S, see our pNOR driver patch at: https://www.cypress.com/products/hyperbus-memory#tabs-0-bottom_side-5.
Gernot
Hi Michel,
Gernot
