we recently bought S26HL01GTFPBHB020 chip to use as flash for our controller. It supports both normal SPI and Hyperbus.
How to check the default communication interface?
I cant find the command sheet for Read/Write operation. How to read the ID from this Hyperflash to verify the communication?
You can refer this KBA as sample to Write /Read operation in semper flash https://community.infineon.com/t5/Semper-Flash-Access-Program/Low-Level-Driver-Semper-Flash-with-Hyp...
Yuvraj
Hi Vicky,
Thank you for contacting Infineon Technologies.
Default communication interface for S26HL01GTFPBHB020 chip is The Legacy (x1) SPI Mode.
Legacy (x1) SPI uses Read Identification (RDIDN_0_0) transaction to read the Device ID and no address is required.
Thanks and regards,
Yuvraj
How can we Read Identification (RDIDN_0_0) without address? How can we read the address?
I couldn't find the command sheet for Read and Write Operation. Can You please provide the link?
To get access to full data sheet we request you to register for our Semper access program by submitting the required details in following page, https://go.cypress.com/semper-access-program-ap. Please let us know, if you face any issues during registration.
Thanks and regards,
Yuvraj
Registration is done. Can you please share the link?
It will greatly help us if you can share any sample instructions for Read/Write.
Hi.
Can You please provide some sample files for Read/Write Operation?
Yuvraj
Yuvraj
Hi Yuvraj,
Thank you for the response.
Can you please confirm the default sector size configuration? Is it uniform 256KB or Hybrid?
By default sector size configuration is uniform.
Yuvraj
