I don’t know if such a flash memory chip can still read the data inside.
andy001
First question asked Welcome!
The BGA package has two flash memory chips, one is on the back side with missing pins, and the other is a chip broken from the middle. The die is located on the upper chip and the pins are located on the lower chip. I want to know whether such a chip can read internal data?
In the picture, the upper one is the BGA pin damaged, the lower one is the flash memory split into two1.png
BushraH_91
750 replies posted 50 likes received 250 solutions authored
Both devices are damaged beyond repair. We will not be able to read out the device content.
Thank you
Bushra
BushraH_91
Thank you for contacting Cypress Technical Support, an Infineon Technologies company. Can you please provide the full MPN?
Bushra
BushraH_91
Thank you
Bushra
