- Email to a Friend
I want to use S26KL128SDABHN030 memory with STM32L4+ microcontroller. I read that this memory has DCARS feature. Is it possible to disable it to use this memory without PSC signal?
- Email to a Friend
S26KL128SDABHN030 requires PSC input to the device, which means you cannot disable this feature.
You need to find standard option with different OPN, Standard option means you do not need to input PSC.
You can use S26KL128SDABHN020 if you don't want DCARS Feature.
Thanks and Regards,
Yuvraj
- Email to a Friend
Thanks and Regards,
Yuvraj
- Email to a Friend
Thank you!
