Hyper Flash Forum Discussions
KeTa_1341526
10 solutions authored 5 solutions authored 100 replies posted
Could you provide a Flash Memory version of the Pin equivalent circuit as described in the MCU datasheet?
Reference)
- Refer to p.55-p.59 [5.2 I / O Circuit Type] in the following datasheets
   https://www.cypress.com/file/364761/download
Kenji Takahashi
Hello Kenji
Datasheet: S26KS512SDPBHB020 pg 10 signal description documents the PIN TYPE. This and the IBIS model are the two resources which can address this query. We don’t provide such information in datasheet as we don’t have various I/O setting options in our flash devices. The required information is provided in the datasheet table, provided below. The only setting we are providing is different drive strength options which you can configure through the respective configuration register settings.
Thank you
Bushra
BushraH_91
250 solutions authored First comment on blog 500 replies posted
Hello Kenji san,
Please provide HyperFLASH OPN
Thank you
Bushra
Hello Bushra-san,
MPN of HyperFlash is S26KS512SDPBHB020.
Kenji Takahashi
Hello Kenji
Please refer to url for IBIS model. Please let me know if the requested information is not in the IBIS model
https://www.cypress.com/ibis/s26ks512s-ibis
Thank you
Bushra
Hi Bushra-san,
The information I want is not IBIS data.
I want information on the equivalent circuit as described in the MCU data sheet.
Kenji Takahashi
Hello Kenji
Thank you
Bushra
