Can we reuse driver for S26KL512SDABHV020 which uses 65 nm MirrorBit Process Technology for S26HL01GTFPBHB020 which uses 45-nm MirrorBit Process Technology?
Hi Rosen,
Thank you for contacting Cypress Semiconductor.
I would like to suggest you to register yourself for the Early Access Program for Semper Flash. Once registered, you will get access to all the Semper related documents, including migration guides that will provide you a comparison of both the mentioned parts. You can use it to make the required changes to your driver.
Please let me know if you have any queries.
Apurva
Hi Rosen,
Apurva
