- Email to a Friend
Hi, i am using IGT60R070D1 for boost pfc converter.
I am trying to estimate the power losses (switching and conduction losses) before make the system.
The conduction loss is easily calculated, but the switching loss is difficult to calculate because there is an absence of information (ex, Eon and Eoff).
Is there a separate way to receive information about Eon and Eoff?
And doesn't Infineon provide the Plecs simulation tool?
thank you for reading my question.
- Email to a Friend
We have provided encrypted simulation model for CoolGaN FETs which can be downloaded from following link - https://www.infineon.com/cms/en/product/power/gan-hemt-gallium-nitride-transistor/igt60r070d1/#!?fil...
As this is an encrypted model, you should only use Simetrix as the simulation tool.
Switching losses is highly dependent on the driving circuits and several other parameters. It is recommended to find these losses through simulation.
Pranava
- Email to a Friend
Pranava
- Email to a Friend
Thank you for your reply.
The other devices such as SiC MOSFET provide switching energy (Eon and Eff) according to the drain current in the datasheet.
Is there any plan to provide switching energy in the datasheet later?
- Email to a Friend
Currently I am not aware of any plans of datasheet updates.
Pranava
