HEMT (GaN) Forum Discussions
Lucaris7
5 replies posted 5 sign-ins First solution authored
I  want to buy the pluggable wire connector, which can be connected with the EVAL_1EDF_G1B_HB_GAN board. Anybody can tell me?
AZIZ_HASSAN
Moderator 100 sign-ins 50 solutions authored 10 likes received
Thank you for posting at Infineon community.
The connector you can find on Mouser on Digi key. These components are available over there.
BR,
AZIZ HASSAN
Lucaris7
What is its name? Could you please show me any link? I cannot find the exact one.
AZIZ_HASSAN
PFA of link given below. Its same 8 pin header, only you have to select the pitch asn your voltage and current rating.
https://in.element14.com/phoenix-contact/1803484/connector-header-tht-3-81mm-8way/dp/3913120
BR,
AZIZ HASSAN
Lucaris7
Since I need a female connector, as the graph shows. Do you think this can work?
https://uk.farnell.com/phoenix-contact/1757077/terminal-block-pluggable-8pos/dp/3705407?st=pluggable...
AZIZ_HASSAN
Yes if the pitch matches it will work. To select female connector, you need to check the pitch and number of pins.
Since, there are many connector type available like vertical, 90 degree press fit , screw fit etc. you can use any one of them based upon  your suitability.
BR,
AZIZ HASSAN
Lucaris7
Thank you
