I am looking for rated or maximum current of Vcc1 and Vcc2. I have checked datasheet. I only see Quiescent currents (IQ1 and IQ2).
What are the values for supply currents (Icc1 and Icc2)? The datasheet is attached.
Hello @meakdogan ,
The secondary side input current of VCC2 (ICC2) would be equal to Iq2 + the current needed to drive the IGBT or MOSFET. The current required to drive your switching device would depend on your application design i.e., Vgs, Rg, switching frequency etc.,
However, maximum limits for the high level output peak current is specified in the datasheet for certain operating condition and the same has to be considered while designing your gate drive circuit components.
I'm checking with the internal team for primary side input current value (ICC1) when the inputs are high. I'll update you soon.
Meghana
