User17583
10:20 PM
- Email to a Friend
I am using IR21814S for LLC gate driver, and I need to limit the minimum duty of PWM signal. Could you help address the minimum HI/LI on pulse requirement for IR21814S? Thank you.
04:44 AM
- Email to a Friend
HI,
For minimum pulse requirement, you can refer to drive input filter operating frequency which you convert to time will give you minimum pulse width which could be passed from input to output.
BR,
AZIZ HASSAN
05:41 PM
- Email to a Friend
We recommend using the 2ED21814 for LLC gate drive applications. Pls write to me at srivatsa.raghunath@infineon.com and I will share the preliminary datasheet of the
2ED21814 along with its timing information.
Thanks and regards,
Srivatsa
Thanks and regards,
Srivatsa
User17583
11:00 PM
- Email to a Friend
Thank you for the support. Actually I can not change the device due to project schedule. I do need to know the minimum HI/LI ON pulse requirement for IR2181S, since I need to limit the duty in the software. Could you help check this parameter for me? Thank you!
04:44 AM
- Email to a Friend
HI,
BR,
AZIZ HASSAN
