Is there a cheat sheet to clarify part number suffixes UM and LL?
Specifically, what are the differences between 2ED2304S06FXUMA1 and 2ED2304S06FXLLA1?
These appear to both be 650 V Half Bridge Gate Driver IC with Integrated Bootstrap Diode (BSD)
webpage @ https://www.infineon.com/cms/en/product/power/gate-driver-ics/2ed2304s06f/
Greg
Gate Driver IC's
Hello @GrCa_1363456
Thank you for posting your question.
The last 5 digits will tell about OPN(Orderable Part Number). The electrical parameter differences will not be there, the only difference is packing type and packing size.
In your doubt, my answer is mentioned below.
UM- Tape &Reel with 330mm
LL-Tube with <=40mm
Thank you
Guru
For additional details Please refer this link
https://www.infineon.com/cms/en/product/search/opn/orderable-part-number-opn-translation-table/
Hello @GrCa_1363456
LL-Tube with <=40mm
Thank you
Guru
