Mar 02, 2023
01:47 AM
Mar 02, 2023
01:47 AM
We are developing a high voltage (450V to 850V) BLDC driver for electric vehicles,
Using IGBT driver, PN 1EDI20I12AF.
We have a technical question:
As the IC is suitable upto 1200V, the high side drive will have Ground reference of High Voltage (850V) on pin 8,
while the Pin 7 is just 0.65 mm far, Pin 2 is 4.5 mm far,
How does it pass the creepage test?
Doesn't the voltage jump to other neighbouring pins?
Please help us clarify this point.
Labels
ispn:2017:1:0
l1:144:1:0
l2:1244:1:0
- Creepage
- high voltage
01:37 AM
Mar 06, 2023
01:37 AM
Hi Anurag:
Thanks for your reference, 1EDI20I12AF is not automotive gate drive IC. Would you like double check it?
This is list for your application:
Would you please cloose "active and preferred" "automotive" product for your design.
01:37 AM
Mar 06, 2023
01:37 AM
Hi Anurag:
