User22680
Hi all,
Do you know how can I verify that the gate driver I am selecting from infineon is UL listed?
I am struggling to get the UL number from the datasheets.
Thank you very much in advance,
Nick
IrisLi
Welcome! First reply posted First solution authored
You can filter for all UL certified gate driver on the gate driver main page, product table. https://www.infineon.com/cms/en/product/power/gate-driver-ics/#!products
5387.attach
Pablo_EG
Moderator 250 sign-ins 250 replies posted 25 likes received
Hello Adams,
You can see the certifications your gate driver model has under the "certificates" tab on the product's page.
For example, for 2EDS8265H : https://www.infineon.com/cms/en/product/power/gate-driver-ics/2eds8265h/#!documents
In addition, the datasheet shows which certifications the product has passed if any.
Below is the example for 2EDS8265H.
5380.attach
Usually, only reinforced isolation drivers go through the certification process.
If the model you are considering does not have a certification, the "certifications" tab in the product page as well as the certification-related tables in the datasheet will not be available.
Pablo
User22680
Thank you very much Pablo.
This is clear.
Just for my knowledge could this be a limitation to achieve electrical safety under UL- 61800-5-1?
IrisLi
5387.attach
