The_BOOM
12:37 PM
- Email to a Friend
We only need a unipolar positive DC voltage.
Can the IRA2153SD work with a simple two-winding transformer and a full-bridge rectifier?
What are the drawbacks?
Is there a different Infineon device that would work better in this configuration, such as a full-bridge gate-driver?
08:46 AM
- Email to a Friend
Yes. The IC biasing conditions including the VCC should be met with the rectifier. See below application notes:
https://www.infineon.com/dgdl/Infineon-Choosing_the_correct_dropping_resistor_value_for_IRx_control_...
https://www.infineon.com/dgdl/dt98-1.pdf?fileId=5546d46254e133b401554de8ed5d5e0f
05:59 AM
- Email to a Friend
The IRS2453D is a full bridge gate driver based on the IR2153D self-oscillating half-bridge gate driver IC.
The_BOOM
03:25 PM
- Email to a Friend
can the half-bridge driver work without a center-tap, by using appropriate rectifier?
08:46 AM
- Email to a Friend
