yumengcai
First question asked Welcome!
I want to use the driver board 2ED300C17-S to control the turn-off of the IGBT in the following short circuit operation of SiC MOSFET.
When the short current reaches 600A, the IGBT is switched-off quickly in order to avoid SiC MOSFET explosion.
how should I set the Rsx and Csx of the driver board 2ED300C17-S to realize the turn-off the IGBT within tens of nanoseconds when the short-circuit current  reachs 600A?
short circuit operation:
Short-circuit current in case of thermal runaway if there is no control:
AZIZ_HASSAN
5 likes given 250 sign-ins 100 solutions authored
Looks like same query is raised on case management as well. So, in order to avoid the duplication, i request you follow up the question on my cases.
I hope you understand.
Thanks and regrads,
AZIZ
AZIZ_HASSAN
Thanks and regrads,
AZIZ
