User22540
First question asked Welcome!
Dear Team,
Good morning.
We are using your 1EDI60N12AF in our simulation.
I would like to confirm few things below before explaining the issue.
We have used/given,
1.VCC1=5V supply(DC)
2.INP=3.3V ADC having 10KHz switching frequency and 60% duty cycle
3.INN-Grounded
4.VCC2=15V Supply(DC)
5.Gnd2=- 5V(Negative 5V) DC supply given in order to completely turn of switch(IGBT/mosfet)
Issue in simulation:
The given model is only working for VCC1=3.3V
If we give 5V in VCC1 then in output we don't get gate pulse instead we get -5V DC(steady DC Value).
As per datasheet we can give up to 15V to VCC1 pin.
Kindly provide us support and solution as early as possible.
Thank you,
Girish Kantharaju
1211Shukla
100 replies posted 10 likes received 25 solutions authored
Hello Girish,
Good day!
Are you trying to fire a device in some configuration or topology? Can you share me your simulation model? I will try to replicate the same
Rishabh
