mukeshp11
10 sign-ins First like received First reply posted
Hello All,
We are using 1ED020I12-F2 gate driver for driving three phase inverter with 6 IGBT modules and each IGBT module is being driven by 1ED020I12-F2 gate driver.
We are using single (i.e. unipolar power supply) of +15V. I am assuming that as this IC has feature of Active miller clamp which will prevent dv/dt turn on failure and hence there is no need to give bipolar i.e. -ve  supply also.  Am i correct with this?
Question is as we have not used negative power supply is it ok ? or do you have use cases with 1ED020I12-F2 gate driver with only positive power supply and up to what rating of IGBT module.
Pls suggest.
Mukesh
Mukesh
yifei_y
25 likes received 100 solutions authored 100 sign-ins
Hi Mukesh,
The active miller clamp function prevents parasitic turn-on caused by miller capacitance, so there is no problem if 0V/15V unipolar power supply is used. As an example you can refer to the eval board .
Active miller clamp is designed for miller current up to 2A. If ICLAMP exceeds 2A you can choose other driver ICs with CLAMPDRV to boost clamp current, like 1ED34x1MC12M
yifei_y
Hi Mukesh,
