Are there any design files (Gerber etc) available for the 2ED100E12-F2 gate driver board? Also, is it possible to purchase these boards from Infineon?
ispn:1946:1:0
l1:314:1:0
If you want to find similar evaluation board, you can go through the following links:
https://www.infineon.com/cms/en/product/power/igbt/evaluation-boards/
However, it seems like no result. You can double check the 4 boards which are ready.
Kieran
The board is out of stock now and it was produced a long time ago. You could get the information of the schematic and PCB layout from the application notes.
Kieran
thanks Kieran, do you know if there are another other gate driver boards with equivalent functionality that Infineon still produces and have in stock and/or provide the design files?
Kieran
