Re: IR2103S not outputting any signal
Tonci
5 replies posted First reply posted First question asked
Phases A and B now work. Phase C has the exact same components, which were changed many times, so I assume that the component values are not faulty.
I have however removed MOSFETs from phase C, and the HO is still not outputting a proper signal. I have atatched HO signals from phase A that works, and phase C that does not work yet.
yifei_y
250 replies posted 25 likes received 100 solutions authored
Phase C may have a broken driver IC, you can try with another part.
Br
YF
yifei_y
Br
YF
