Oct 17, 2022
05:37 AM
Oct 17, 2022
05:37 AM
Hi, Sir.
I am using IR2104 IC for pwm amplifier, where I am using 50Khz, 3.3VPP pwm signal in input section. But I did not get any pulses in HO,LO.
Kindly tell me, SD should be high or low to active the ic.
Labels
ispn:14010:1:0
l1:144:1:0
l2:1244:1:0
11:58 AM
Oct 17, 2022
11:58 AM
To get the gate driver output at HO and LO, SD Should be high. Please refer to the timing diagram attached below.
Rishabh
11:58 AM
Oct 17, 2022
11:58 AM
Rishabh
Nov 09, 2022
09:37 PM
Nov 09, 2022
09:37 PM
Do you need further support on this issue?
Rishabh
