- Email to a Friend
Hello, I'm using the gate driver 1ED3122MU12H for my three phase inverter application. I would like to know about the output capacitor's calculations, which I've found in the application note for the family of drivers.
My query is, how should one go about looking for the frequency responses while selecting an output capacitor based on these formulas? Thanks and Regards
- Email to a Friend
Hi @asrikrishnagovi,
yes. correct
it is the same as a bootstrap capacitor in the case of non-isolated drivers, supplying the required gate charge.
Malleswararao
- Email to a Friend
Hi @asrikrishnagovi ,
Thanks for posting your question in the Infineon community.
I need some more information about your question as below.
Can you share which application notes you are referring to?
May I know which output capacitor calculations you are looking for?
Malleswararao
- Email to a Friend
The formula was taken from page 8 EiceDRIVER™ 1ED31xxMU12H (1ED-X3 Compact) (infineon.com)
I'm referring to the output supply capacitors . Wanted to know how to look for appropriate frequency response of the capacitors based on the capacitance value I obtain.
- Email to a Friend
Thanks for your data.
For better understanding and time being, I will consider the same conditions which are given in the application notes to explain.
with the above data, C2 is 5.34uF without a 20% margin and
with a 20% margin C2 is 6.4uF
with this, I want to put 4.7uF capacitors 2 no's in parallel. due to DC bias, Frequency response & temperature characteristics. please go through the below explanation.
From the above graph, it is observed that the capacitance value is reduced by 22.7% with 15Vdc
The capacitance change with DC BIAS (4.7uf / 2 Nos in parallel) is 2* 4.7uF* 0.773 = 7.26uF
From the above graph, it is observed that again capacitance value is reduced by 25.9% at an ambient temperature of 60degC
The capacitance change with temperature is = 7.26uF*0.741 = 5.38uF
which is matching with our above calculation of C2.
Now we need the Peak current capability of the capacitor for that, it is necessary to calculate IGBT(FP100R12KT4) gate Peak current. As per datasheet conditions as shown below high lighted and internal gate resistance is
with the above graph at 15kHz, resistance is 0.02ohms
Conclusion :
it is required a 4.7uF / 50V capacitor of 2 no's in parallel to connect to the output supply for the above example case.
Accordingly, you may select a suitable capacitor for your application.
Malleswararao
- Email to a Friend
What is the significance of this Capacitor? Is it similar to the bootstrap capacitor in case of non-isolated drivers, supplying the actual required gate charge, or is this capacitor needed as a supply filter?
- Email to a Friend
yes. correct
Malleswararao
