WalmirSantos
First like received 10 replies posted 5 questions asked
Hello Guys,
We are building  a schmetics with IR2183S + IRF1010E. The 1,4A current is not reaching the mosfet gate, according to the datasheet. The cuurent is much smaller. We aren´t understanding why.
Can someone help me?
Walmir
Meghana
50 likes received 100 solutions authored 10 likes given
Hello @WalmirSantos ,
Yes. Your understanding is correct. Maximum output source current on HO pin is typ 210mA (min -130mA) @Vo=0V & Vbias=15V. For different Vbias condition, the output source current can be derived from the characteristic graph provided in Figure 22B in the device datasheet. Vbias condition in your simulation would be different, hence you are observing different Io+ value.
Meghana
Meghana
Can you please let us know what are the drive voltage levels and  Rg value used in your design?
Meghana
Hello Guys,
VCC=15V and Rg=4.7ohms
We are using the simulator Infineon and We had a output current on IR2104 Igh=300mA (peake) and Igh=262mA (nominal), but in datasheet We have a nominal current IO+=210mA (output high short circuit pulsed current.
Is it correct?
Walmir Santos
Meghana
Hello Walmir,
Let me try the simulation on my end. Will get back with the results.
Meghana
Thank you very much.
The IR2104 drains on your HO only 130 mA for charge. This is my doubt.
Meghana
Meghana
Meghana
Thank you very much
