MOSFET Driver Choosing
SimonC
Distributor - Avnet(GC)
5 sign-ins First solution authored First reply posted
Dear Infineon:
Current I have one device for choosing how to driver it.
  1. In direct mode with GPIO control of device. Which GPIO1 controls the DSG FET, another GPIO2 controls the CHG FET.
  2. Register Control can be configured as simple control mode. Logic: rising edge active? or level active?
Some comments for my reference? or data for my study?
vigneshkumar
250 sign-ins 50 solutions authored 100 replies posted
Hi Simon,
MOSFET selection:
You can choose MOSFET in the below link based on your current requirement. VDs 150Vds ,
 Id @ 100 deg C should be 1.5 times your max current.
https://www.infineon.com/cms/en/product/power/mosfet/?filterValues=~(473_max~(leftBound~130~rightBou....
Gate Driver:
IRS2118
 Switiching MOSFET
Gate driver requires active high and Low to switching MOSFET. Below llink will give you detailed explanation about driving  MOSFET.
https://www.infineon.com/dgdl/Infineon-Gate_drive_for_power_MOSFETs_in_switchtin_applications-Applic...
I have one question
Rising edge active or level active, is this about MCU internal thing?
Vignesh kumar
vigneshkumar
Hi Simon,
Thanks for posting on the Infineon community,
Could you please elaborate more?
Vignesh kumar
SimonC
Hi Vignesh:
Thank you for your support!
Battery nominal voltage is 57.6V, Max Voltage is 67.2V.
GPIO output voltage is 3.3V or 5V.
Would you please help to recommend one type of N-CH MOSFET for my study?
One driver by pin CHG/DSG which is reach to Vtop voltaeg.
Another driver by GPIO1,2 which is reach to 3.3V OR 5V.
Can I learn which parameters of MOSFET be decided to choose the rising edge active or level active?
vigneshkumar
Hi Simon,
MOSFET selection:
Gate Driver:
IRS2118
 Switiching MOSFET
I have one question
Vignesh kumar
SimonC
Thank you very much!
I will continue to do study it.
