Inquiry Regarding Half-Bridge Driver Configuration for Dead Time Variation
Youcef_RZ
5 likes given 5 questions asked 10 sign-ins
Kindly ask whether it's feasible to link the DT pin of the left half-driver with that of the right half-driver, and subsequently connect both to the potentiometer as illustrated in the image, aiming to regulate the dead time of both in such a way that they are equal.Screenshot 2024-04-02 232417.jpg
It is better to use one resistor for each device to set the DT. If you have just one resistor for both, probably it would be placed far from the device and it can show noise problem.
I hope you understand.
Thanks and regards,
AZIZ
AZIZ_HASSAN
50 likes received 5 likes given 250 sign-ins
May I know what is the part number of the driver IC.
Thanks and regards,
AZIZ
Thanks and regards,
AZIZ
