- Email to a Friend
Hello
I want to implement non-isolated LED lighting using the IRS25411S device
Please let me know if you have application notes or data applied to actual products.
- led lighting
- Email to a Friend
Hello @andypark
Thanks for providing the requirements.
PFC stage you can use this reference document for your calculations.
Buck converter stage you can use this reference document.
Both documents have the formulas so please calculate as per your requirement.
Both converters will help for your entire project design.
Guru
- Email to a Friend
Hello @andypark
Thanks for writing to Infineon Community.
The Attached document will help you to design the LED drivers
Please download it from this link
you can refer this Link also for LED application design considerations.
In this attachment Fig-9 will help you for your designs
Please let me know if you need any help
Guru
- Email to a Friend
Dear Guru
Thanks for your support.
The link you sent was well received.
All I need is a Normal reference design guide.
For example, circuit diagram, Trans calculation formula, each part calculation formula, etc.
Please refer attached file(Competitor design guide)
Customer output information
Input voltage : AC90V~264V
Output voltage, current : 60V 240mA
- Email to a Friend
Hello @andypark
Please provide us with complete requirements to us. which topology do you need it Isolated or nonisolated?
The reference design which you attached is isolated topology. In fact, Infineon has an isolation topology kindly click here.
Infineon don't have application board for non isolated topology.
Please let me know if you need any help.
Guru
- Email to a Friend
Dear Guru
I need Non-isolated topology.
If you have a calculation formula by Excel?
Please provide it to me.
- Email to a Friend
Hello @andypark
Please let me know your complete requirements and specifications.
which all are formulas you are looking for please let me know?
Guru
- Email to a Friend
- Email to a Friend
Hello @andypark
Guru
- Email to a Friend
Dear Guru
I will make a design based on the data you sent. And I will contact you.
