CaelebMcKee
Hello there,
I am attempting to run a Altium SPICE simulation with the SPICE model for the IRS21876S, and I'm encountering a few errors. I keep getting a PWL  error about an ngspice expression not being a constant. This confused me since there is no PWL source in the model. I'm not sure if this is a problem with the model or Altium, but I thought I'd post this here to help track down the issue. I've included a screenshot of the error messages with this post.
Altium/ngspice Error MessagesAltium/ngspice Error Messages
1211Shukla
100 replies posted 10 likes received 25 solutions authored
Hi Caeleb,
I tried to simulate Pspice Model of IRS21867S (driver) with the mosfet model IPW60R017C7 in a half bridge PWM converter configuration  in ltspice environment and the model is working absolutely fine. Thus I can assure you that it will work fine in any of Pspice or ltspice environment. ltspice is a open source tool, you can download it and simulate your circuit. I would still not comment about ngspice, whether the model will work well there or not!
Please revert in case of any query
Rishabh S
1211Shukla
Can you share me the simulation model.
Rishabh S
Attached is a pdf file with the SPICE model I am using.
Caeleb
1211Shukla
Hi Caeleb,
Rishabh S
Rishabh,
Thank you very much for the help! I'll switch to ltspice for this task.
Caeleb
