Ramanan
First question asked Welcome!
We would like to know the difference between IRS2184STRPBF and IR2184STRPBF... Please confirm by return immediately.
1211Shukla
100 replies posted 10 likes received 25 solutions authored
By comparing the datasheet both drivers seems to be very similar but there are minor differences with respect to abs max rating  due to difference in abs max low side supply voltage (Vcc) rating, which is 20V for IRS2184 and 25V for IR2184.
A little difference is there with respect to HIGH logic level ( 1 logic) for LO, HO and SD input.
Rishabh
1211Shukla
Rishabh
1211Shukla
Do you need further clarification?
Rishabh
