Hello, I am designing a BLDC, hall sensor, 3-phase motor driver circuit. The switching frequency is 15 kHz. Aluminum capacitor is thrown in the DC bus line. The necessary components for Bootstrap have been thrown. I control the duty with a potentiometer. While the engine is in the air, the engine spins up to high speeds. However, there is a problem under load, there is always a short circuit between the VCC-LO pins of a gate driver. I am using STM32F303RE as control IC and I wrote the software. In some cases, the potentiometer becomes dysfunctional, does not detect it, I have to reset it.
Why are VCC-LO pins always burning in this integrated?
Hi ibronix:
Thanks for your reference. The problem maybe from PCB layoue and drive design.
Would you like share your SCH and PCB layout?
