IR2085S
Sriram_07
10 questions asked 25 sign-ins 10 likes given
Hello , I am building a prototype inverter based on the infineon 22kw inverter reference design. The 50 % duty cycle IC (IR2085s) is not recommended for new design . Is there any driver ICs similar to IR2085 that i could use ?
Thank you
Daisy_T
250 sign-ins 250 replies posted 25 likes received
Hello Sriram,
No direct replacement for it. IRS2153DS has similar functions, but with higher Voffset and lower current drive capability. Please refer to the datasheet for more details.
Daisy_T
Hello Sriram,
Akhil_B
250 sign-ins First question asked 50 solutions authored
Hi @Sriram_07
IR2085S can be replaced by AUIR2085S which is an active and preferred part. The main difference is that IR2085S is an industrial part and AUIR2085S is an Automotive part.
Akhil Kumar.
