Vaibhav
5 likes given 5 sign-ins First like received
I am designing IGBT driver circuit using 1ED3461MU-12m i have to clear some points regarding the IC.
1. I have selected ADJA (28K) whose Icsoff =466mA, that means the gate charge will discharge through Rg to VEE with 466mA current. Please Confirm. 2. During DeSAT Fault condition, Soft off time (tCTSOOS + tCTT) will start after Tdesatout and if the soft off timeout happens then it will hard switch off through clamp pin. Please confirm. 3. Can we reduce Soft off time (tCTSOOS + tCTT) ?
Please review our points and confirm that our understanding is right.
Guru_Prasad
Moderator 50 solutions authored 100 replies posted First question asked
Hello @Vaibhav
The Active clamp MOSFET  should be selected  based on the below parameters
1)MOSFET voltages and currents(Drain and gate) should be checked.
2)The peak current should be checked while it is turned ON. The peak current will depend on your IGBT gate
charge and gate supply voltages. The peak current can be checked in the FBSOA of your external MOSFET.
Please let me know your IGBT charge and driver supply voltage based on that we decide whether the  Si2318CDS
MOSFET will fit or not for your application.
Thank you
Guru
Guru_Prasad
Hello @Vaibhav
Thanks for posting your question in the Infineon community.
YES, The gate charge current will discharge through Rg to VEE with 466mA while ADJA is 28k Ohm
Yes, During DeSAT Fault condition, Soft off time (tCTSOOS + tCTT) will start after Tdesatout and if the soft off timeout happens then it will hard switch (tCTT) off through clamp pin.
No, those cannot be reduced because  those are fixed values.
Please let me know if you need any help.
Guru
Vaibhav
Thank you Guru,
Is there any criteria for selection of Active clamp Mosfet? Now, I have selected Si2318CDS MOSFET.
Is it ok for 1ED3461?
Guru_Prasad
Hello @Vaibhav
Thank you
Guru
Vaibhav
IGBT : SEMiX305GD07E4 and Driver supply is +15V and -9V bipolar supply.
Please check and suggest
Guru_Prasad
Hello @Vaibhav
The Si2318CDS MOSFET can be used as an Active clamp MOSFET for SEMiX305GD07E4 with driver supply of Driver supply is  +15V and -9V.
Thank you
Guru
