The EV market is bigger and better than ever. Join the EV Webinar to find out how you could best utiilize Gate Driver ICs for EVs.
wohehe123
First like given 5 sign-ins First reply posted
I am designing an isolated gate driver using 6N137 and 1EDN7126GXTMA1, but I'm not sure if it's ok to connect the grounds. Because in the datasheet IN- is connected to SGND while VSS is connected to PGND.
yiye_4841451
25 sign-ins 25 replies posted 10 solutions authored
Both GNDs must be separated.
wohehe123
Thanks for answering!
But since I use optocoupler, I already have one isolated ground "GND_DRV", and my isolated DC/DC use this ground too. How can I provide power to the drvier IC 1EDN7126GXTMA1, if the Vss is not connected to this ground, or I don't need an optocoupler anymore? This question troubles me a whole day. I'm a rookie, really appreaciate any reply, thank you
