Vasu
First question asked Welcome!
Hello All,
Greetings.
I am looking for gate driver to use to drive low side back to back connected MOSFET switch to disconnect the battery .
it needs to support common source or common drain configuration of MOSFET's  to disconnect the Battery rail in negative path.
Please suggest.
Vasu
vigneshkumar
250 sign-ins 50 solutions authored 100 replies posted
Hi Vasu,
You can use isolated power supply and connect its ground with Common source N_channel MOSFET. you can use this in low side , negative rail of the Battery.
Based on your MOSFET selection you can the  choose driver (N_channel low side MOSFET driver ).
Could you please share voltage and current rating ?
Vignesh kumar.
vigneshkumar
Hi Vasu,
Thanks for contact Infineon community,
May I know if you have any specific reasons behind using Low side driver ?  We can arrive some discrete solution .
FYI - High side driver for back to back MOSFET - AUIR3242STR
Vignesh kumar.
vigneshkumar
Hi Vasu,
Vignesh kumar.
