Error in infineon driver 2EDF7275F. Unknown parameter 'MinADel'
First solution authored First question asked First reply posted
I recently installed the driver 2EDF7275F for Simetrix from the infineon website. There´s an error that appears many times that says "Unknown parameter 'MinADel'".
And the download brings two archives .lib, one is the 2EDF7275F and the other is named  "BaseComps_SIMetrix" and I don´t know what is the second one.
Hope someone can help me.
We have found that there is a problem with the model file and will share you once it is fixed. Thanks for letting us know.
Thanks and regards,
AZIZ
AZIZ_HASSAN
5 likes given 250 sign-ins 100 solutions authored
Can you please share the error image here and the file which you installed.
AZIZ
Here you are
And the file is download from here in simulation models: https://www.infineon.com/cms/en/product/power/gate-driver-ics/2edf7275f/?tab=~%27simulation_models#!...
I´m using the simetrix one
AZIZ_HASSAN
I am working on it. Please give me some time.
AZIZ
Sorry for the delay. Looks like there is some problem with model file. We are still checking it internally. Please give me some time to get back to you.
Thanks and regards,
AZIZ
Thanks and regards,
AZIZ
PFA of the SIMetrix lib file which must be attached to the library file in order to run the simulation file. I am sorry for the inconvenience caused due to missing file in the library and I hope this solves your issue too.
Thanks and regards,
AZIZ
