Oct 19, 2019
09:54 PM
Oct 19, 2019
09:54 PM
I have attached the circuit. I'm trying to drive a coolgan HEMT (IGOT60R070D1) with driver - 1EDF5673F.
PROBLEM - 1) When I tested the driver alone (without connecting the switch and the power circuit), the driver always shows -8V as output at the "gate to source terminal" irrespective of what I give at the PWM input pin.
PROBLEM - 2) When I soldered the gan switch, the SK pin of the switch draws considerably high current (more than 200-300mA). (drive still gives -8V between G-SK of device)
Can anyone help with this problem? What am I missing?
PS: I have soldered two boards with new components to confirm the above symptoms. So i'm sure its not the soldering issue or damaged ICs.
04:34 AM
Feb 23, 2022
04:34 AM
For problem number 2 if you try with different gate resistor and share us the current consumption result, then I think we can comment on that.
BR,
AZIZ HASSAN
Oct 22, 2019
12:12 AM
Oct 22, 2019
12:12 AM
It looks like the input side you are using a 5V VDDI solution as evaluation board application note.
As you are using a 3.3 VDDI, SLDO should be grounded to disable the shunt LDO voltage regulator and 470ohm shunt resistor should be removed as descibed in datasheet as below.
I would assume the main reason would be the input side of 1EDF5673K is not correctly supplied so that you only have -8V output as no switching activity.
If you have a voltage higher than 3.5V as in application note (5V), you can find the reason in datasheet below.
Dec 09, 2019
06:42 AM
Dec 09, 2019
06:42 AM
Hello Vinc, thank you for your response.
You correctly identified the cause of the first problem. Using a 5V supply on the input side of the driver did solve the problem. - PROBLEM-1 SOLVED - USE 5V for VDDI WHEN SLDO IS GROUNDED.
Dec 09, 2019
07:05 AM
Dec 09, 2019
07:05 AM
One serious note about 1EDF5673 - IT IS A FULL BRIDGE DRIVER - hence, you can NOT short the driver ground with the source of the switch. - So, an ISOLATED DRIVER SUPPLY IS MUST with 1EDF5673 even if you just want to make a simple boost converter.
If you are using half-bridge driver like 1EDI20NAF, YOU CAN short the driver ground with the source of the switch - so isolated supply not required.
Refer to follwing images from infineon showing these circuits:
________________________________________________________________
This justifies the PROBLEM-2 in the original post. I was not using an isolated supply.
Feb 23, 2022
04:34 AM
Feb 23, 2022
04:34 AM
BR,
AZIZ HASSAN
