Lee_apple
5 sign-ins First reply posted First like given
Please help me recommend three driver chips for SiC Mosfet: "IMW120R020M1H1", "IMZ120R090M1H", and "IMW65R039M1H".
I consulted the "Infineon EiceDRIVE Gate Driver IC Selection Guide", but could not find any recommended driver chips for these three mosfets.
My MOSFETs are used in a pulse current power supply and do not have any special driving requirements. If possible, please recommend a few more driving chips. Thank you very much.
Klaus_Ma
100 replies posted 100 sign-ins 50 solutions authored
Hello  ,
From the Gate_Driver_ICs-ProductSelectionGuide you could find the corresponding SiC driver in various application field like EV-charging, Solar and UPS.
IMW120R020M1H share the same driver IC with IMW120R030M1H, you could try search with IMW120R030M1H instead.
The difference between IMW120R020M1H and IMW120R030M1H is in Rdson, they are the same series of products, and mostly they could share the same driver products.
Klaus_Ma
Hello  ,
Thank you very much for your timely response, which was very enlightening for me. Thank you.
Klaus_Ma
Hello Lee_apple,
Please Login myinfineon and try if you could get the access.
https://www.infineon.com/sec/login?ret=https%3A%2F%2Fwww.infineon.com%2Fcms%2Fen%2Fproduct%2Fpower%2...
